Guys…Sounds like cutting at the outers definitely makes better sense. Maybe building up a long side front axle could be the exception but I’m not there yet. Been looking at other builds and Hinmation’s 3 link currently but wow, as he says it’s challenging.
Yeller: I have been trying to keep up on your Jeep build as well. Have seen some alignment bar use in pics and somewhere use of a string line to check alignment. I’d sure want to get it real close but I’m not sure I’ve seen any actual tolerance specs mentioned. P.S. Can I borrow your x-ray machine?
Q: (Don’t take this as a reference to the Star Trek character)
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I”m probably using this as an excuse to pickup a mag drill. Manhandling a hand drill is getting to be more of a struggle. Even the midrange Evomag I’ve been looking at is pretty spendy but a drill press isn’t cheap either.
James: I wouldn’t have thought about the hardening issue as I’ve not tried anything like that. No stranger to burning bearing races out of hard to get places, but you have the advantage of the boundary between the two. I have used a torch to cut partially into parts but it’s really imprecise and can be hard on tips as well. Cut a bit, knock the slag out, cut some more and so on. Not much fun!
This is for the Bronco. Was looking at FF mods to the 9“ and options seemed to say go with something made for it rather than throw a lot of money at it. The 2nd gen 10.25 seems to have a decent rep because of the bigger inner pinion bearing and I’m looking at picking up the Ford e-locker. I’ve seen online dealer listings of them for around $500 if their legit. The 9” offerings are air only as far as I know. I actually considered the Ox locker as well. The cable system would not rely on electric or air, but the downside is the price. They don’t work for a 9” because they use a back cover for the shift mechanism. Just my reasoning right or wrong along with a lot of procrastination.
![Slightly frowning face :slight_frown: 🙁](https://cdn.jsdelivr.net/joypixels/assets/6.6/png/unicode/64/1f641.png)
Thanks! Scott
