FoMoCoBronCo
- Feb 20, 2023
- 72
Hi, I recently purchased a NOS 1971 Ford Bronco "BUSHING & INSULATOR KIT" Part # C5TZ-7343-A. I have a manual transmission with column shifter and the 1st gear & reverse gear linkage bushing was shot.
I removed all the old parts and saved the washer and wavy clip. After getting the rubber bushing and brass sleeve installed, I realized that the metal part of the bushing needs to be flared flat at the end to keep the washer and rubber bushing all compressed together as one piece, and also to make room for the groove again for the wavy clip to sit in.
The old brass bushing had that flared end that I had to crush with a pair of lineman pliers to get everything out.
I'm wondering if there is a special flaring tool that Ford used to make this specific flare and, if so, where could I find it? Or is there a flaring tool that most mechanics use to accomplish this? I don't think my brake line flaring tool will work because it doesn't leave a 90-degree bend at the tip- it would be angled instead
