5buckaroos
- Apr 18, 2003
- 2
Could use some ideas on caring for my '71
Out of the blue-not speed dependant but usually 30-40mph range, a touch on the brakes and I'm out of control. Doesn't happen alot-could be 15 miles without incident. Travel now reduced to "is someone dead".
I have no determined cause other than it seems to be related to braking. Turning or rolling over a few bumps while initiating braking also seems to facilitate it. The only way to stop it once started is to stop the vehicle.
-Lugs tight
-wheel bearings adjusted
-brake pads new
-rotors new but port side seems slightly warped
-slight play in both upper ball joints
-all other joints feel tight-did not disassemble
-nothing visibly broken
-wheel balance not checked but assumed this would
cause a more consistant problem and would relate to
speed.
Running short on things to check and not wanting to throw $ at it until it obeys. rocked my world the first time. Wife followed as I gimped home. She viewed once and said front left tire was going to let loose - very obvious from her perspective but nothing obvious to me. Any advice welcome.
-Lugs tight
-brake pads new
speed.
