Hello,
I am requesting some assistance. I am replacing the drum brakes with rotor/caliper conversion kit. At this time, I am converting the FB to rotors and leaving the BB as drum, albeit new spring,shoes...etc. I haver also purchased a new master cylinder, as well as new brakelines.
The new master cylinder is the Ford F250 "Camper Special." For anyone looking for a part number, the rebuild is Cardone 10-1638. TBP said to ask advance auto using, 78 F250 2wd, 360cid with ports on left side.
Question: The old master cylinter brake rod appears to be permanently attached. I removed the c-ring, to remove the plunger, but even after taking the rod, spring, bushing, out of the old master cylinder, I see no way to re-use this rod. I don't recall reading anything about this during my research. The new master cylinder has no push rod included, nor appears to have a way of attaching a rod internally.
What am I missing?
My bronco is a 1975, 302cid v8, automatic
New Master cylinder, Cardone 10-1638
The brake conversion kit was purchased from tom's bronco parts,part# 2434
What am I missing?
