Mastercraft seat mounting Brackets?
Mono
Seat Mounting Brackets
#4739 D or P, Mounting Brackets with Slides, Specify side
$179.95
Anyone running mastercraft seats without spending $400 on seat brackets w/sliders from the major vendors?
Any aftermarket solutions?
Mono~
Mono
Mono
I made an offer on these, and won them for $300-
Mastercraft sportsman's
I just can't see spending all of $400- to get them mounted :cry:
Apogee
I'm running my OE '77 sliders and brackets until I have the time to make a cage with seat mounts. IIRC, it needed a few washers as shims between the seat and the slider, but otherwise more or less bolted right in. I'm running the Sportsman in case it makes a difference.
malcolmzilla
Calgary, AB, Canada
I don't know if the Mastercrafts have a specific bracket pattern, but Jegs and Summit carry seat slider kits for way less... Do you even need the passsenger side to slide?
Mono
Mono
I'm guessing you hard mount the passenger side because the seats do not fold forward, and you'd want it @ the same level as the drivers-
Stock brackets will work?- hu- Wish I had a set laying around to try! How did you mount the passenger?
Bundy
I have mastercrafts and when i found out how much the brackets were i told them to pound sand.
Bolted them to the floor with large washers and good hardware... used the stock brackets for the passenger side.
4lofun
i got my slides from mastercraft fot sportsmans. been a few years but wasnt more then 100 for both seats.they seemed like they were just universal stytle and mounted them to my rollcage
