For fs sake. Is there anything harder to do on these?
Please submit any suggestions.
1. Yes, this distributor had been seated previously. Pulled to turn 180 and now I can't get it to seat.
I've gone as far as marking the rotor to show where the hex is set at the end if the shaft, and marking the top of a hex tools so I can turn each and know where it is.
Then after rotating I have to center the pump so it sits in the middle of the hole so that the distributor can receive the shaft as it descends into the depth if this forsaken block.
I don't want to tap or force it as it may push the shaft down. Or is it okay to persuade it from the top?
So frustrated
So frustrated
