iwlbcnu
- Nov 1, 2001
- 3,342
drivers side chrome corner trim piece, in good useable shape except one end is slightly tweaked and needs to be spread back out, should be easy to fix $5
beltline chrome front fender point, useable, but needs a dent knocked out. $2
beltline chrome front fender in good shape but has overspray on it $9
beltline chrome front fender in useable shape but the door end has had 1/8 inch cut off and a screw hole in it $5
beltline chrome front fender in useable shape but the door end has been bent out a bit, should be an easy fix $9
piece of chrome behind the seats that holds the mat or carpet down, both ends are rough for about 1 inch $4
beltline chrome for the drivers rear side, corner end is flattened and will need to be fixed $6
beltline chrome for the drivers rear side, center is flattened and will need to be fixed $6
beltline chrome for the passenger rear side with a tire carrier, and is slightly tweeked but should be fixable $6
beltline chrome tailgate piece that is flattened on one end $6
beltline chrome tailgate piece that is pretty tweaked, but may be fixable if you have the time $2
Ranger interior tailgate trim, only 2 pieces and are scuffed $12
rocker chrome trim, three pieces, but the sides are cut out for some reason and have screw holes in them $12
rocker chrome trim, one piece, drivers side I think, have screw holes in it $6
looks like my contributor status ran out, check out my gallery
