Tuff68
I posted on here 2 weeks ago that I had installed my rebuild 302 and new clutch, and had a bad screeching noise when I pushed in the clutch.
Droped the trans/tcase and checked everything with all looking good.
Reinstalled the trans/tcase with the second new throw-out bearing only to have the same noise issues.
Started looking under the hood with the clutch ped pushed in and see that THE CRANK IS MOVING FORWARD, causing the flywheel to contact the back on the motor.
WHAT DID WE DO WRONG. The only thing not new inside the block is the crank and I had a mach shop check and polish it. They also did the block work.
I'm lost at this point.
