Moving body to temporary frame...Question?
sooner-sig
Horn Lake, MS.
Okay so I bought a rolling frame, Got the glove box and title as well. All for $350. I'm going to use it to store my body on while I do a frame up resto. My question is this. Some of the body mounts are missing, so should I get some to replace the missing ones, or should I cut off the rest and just put the body directly on the frame?
Bitch'nBronco
Loose Cannon
Ringwood, NJ
If you're looking for a quick fix, then I'd just stick a sawed off 4x4 post where the mounts are supposed to be. But the real answer is to just replace them
S
sooner-sig
Horn Lake, MS.
So directly on the frame is out of the question? Why? What am I missing? Since it's a bad idea next question is. Anybody have some old body mounts for sale. I hate to buy two sets one for temporary use and the other for the frame off resto.
hose101
are you looking to reuse the new frame when your done? If so replace the body mounts with new ones. If not just weld in any steel you got that can handle where the mounts are suppose to be. Are the mounts completley gone or are they just rusted out?
S
sooner-sig
Horn Lake, MS.
The frame mounts are solid. I'm refering to the rubber mounts. The ones most guys saw off and then replace with polyurethane ones.
