I moved the back axle rearward about 7". That is about as far as you can go by just moving the exhisting springs till you run out of frame. I have 3.5 lift and have never hit the axle on the crossmember. The wheelwells need to be patched in, and I filled in the fenders so it looked nice. I had a 24 gal. tank so I trimmed it a bit so it would fit up between the crossmembers, the botton is flush with the botton of the frame, and the top goes into the bed about 5".
