My Saturday Sub install... *PICS*
JK
Kent, WA
Now that I have the top off, I had to rethink the subwoofer placement. I had a box behind the rear seat, but I might as well put a neon "Steal me" sign on it the way it sat. I thought about bolting it down, but I like it easily removable for when I decide to fold and tumble the seat and load up the dogs for a ride. In the spirit of theft deterence, I went with a rear quarter install because the rear hoop of the cage will mount directly in front of it, making it impossible to remove the sub with the cage in place. Pretty basic install, fiberglassed a mold of the interior of the quarter, cut a 3/4" MDF panel, screwed/glassed them together, etc. I cut a couple spacer rings from MDF to bring the sub out 1.5" for basket clearance and overall airspace reasons. A little body filler to finish out the curves and some carpet and I'm in business. I didn't spend much time finish sanding the filler, since the carpet was backed and fairly thick, it shows nothing. Sounds pretty good for a 12" shallow mount in a topless vehicle. Here are a few pictures of the process. I'll post the final product when I get the cage, seats, etc. back in.
Dennis112885
Millville, NJ
Did you have to make any electrical upgrades to run an amp and sub setup? I'd like to run a 4 channel for highs and a mono for a sub but my lights barely stay lit at night. So I'm thinking I might need to make some changes to do so.
Captain Ken
Out to Sea
That's fantastic! I'm wrestling with the same problem now and would be very happy to hire you to make a couple of more of those if you still have the mould.
KyleQ
Totally love it - now you just need to make a few more, one for the other side and two for me!
WheelHorse
Looks good man! How badly does the ole tin box rattle hitting the low bass?
JK
JK
Kent, WA
I did the 3G Alternator conversion. You can find it on here in a search. It's very basic and bumps you up to an internally regulated 130A charging system. I run the front highs (5.25's) off of the deck. The rear wakeboard tower speakers mounted to the cage are powered by two channels of a DB Drive Okur 125.4, with channel 3&4 bridged to the 12. Works pretty good and it fits under the rear seat.
JK
JK
Kent, WA
I'd be happy to help anyone around here out if they wanted to give it a shot, but the glass mold is gonna be fairly vehicle specific. Carpet, original floors/fenders as opposed to replaced sheet metal, all things that could make the panel not fit worth a crap. You could go a bit smaller to be on the safe side, but you really need all the airspace you can squeeze out.
JK
JK
Kent, WA
The other side I just did a flat panel with no sub. There just isn't enough space for a real install on that side with the filler necks. An 8" maybe, a 10" tops, but no 12". I'll probably mount a fire extinguisher or something where the sub would be on the opposite side. If anyone wanted just a paper template of the actual trim panel, I could probably help ya out there...
KyleQ
I'd be game for something to start with - if that entire enclose pops out you could measure each side so someone could reconstruct it out of some other material that isn't fiberglass ;)
Looks awesome BTW - right now the only music I get form mine is a screaming 351W :cool:
SpareParts
Looks good, can't wait till I'm done with my stretch so I can start my install.
JK
JK
Kent, WA
I finally got the Centrapod in so I could pit the door inserts on. I'll have to shoot some pictures of the total install now.
