71 SPORT
Is it normal for my fuel filter to be near empty all the time ? Even on start up (no heat) , if i turn the key to the on position it will fill up almost all the way but while running it nearly empties and bubbles up some fuel occasionally. I have a carter electric pump and i just redone my fuel lines with metal lines on the outside of the frame rails , thinking possibly a pin hole in the rubber hose on the sucking side but still nearly empties out. It stays around 6 psi and doesn't stall . its not the tank i installed a new 23 gal. and the filter before the pump fills up completely and stays that way. Is it possible the selector valve is not sealing off completely from the aux tank (i rarely use the aux tank and is usually empty) ? I have one of those glass filters to see this happening .
