Need Bilstein Shock Advice
crab
Are the 7100 worth the money or will I get just as good of a ride with a cheaper shock like Duffs? They're going on a rock crawler and some dune running. I am VERY abusive and have blown many Rancho's in the past from over heating. Just looking for some feedback from people running them.
68ford
i will never nuy a resivor type shpcks again that arent bypass. 9100s or like me, Kings ;D love em!
Socal Tom
San Diego, CA
Yes, they are worth it. I've burned through several sets of 9000s and 5000 ranchos. With ranchos they warm up really fast in the dunes. I would come home after a weekend, and the shocks would show that all the travel was used, and my bumpstops got a work out.
With the 7100s ( 12 inch short body resivor up front, and 10 inch w/o resivoir in back) I don't bottm out. If you hit a bump too hard, you brace for the hit, but it never comes, even after the shock gets warmed up. In fact, the ride just gets a little smoother after it warms up. I'm running the 360/80 valving in front and the 270/? in back. They work great. The only time I've seen them bottom out is rock crawling when I get twisted up real good. At speed they seem to firm up and "catch" you before you hit hard. It's really impressive.
I should add, that in order to work well, you need good solid shock mounts. I've had to remount my f250 mounts once because they weren't attached well enough.
Tom
toddz69
I don't see any pictures of bypass shocks in your gallery though. Where are they?
Todd Z.
68ford
they are mount almost same angle as wh extreme hoops,litle more straight up and down,the hoops are about 2 inches taller though,i have a crossbar to stop flex but its all sealed off from outside, theres one pic i think you can see them barley,just coming off the ground,the pic is taken looking at drivers side and im going to the left of the screen, ill try to post it.
showphoto.php
68ford
there 2.5in body diameter 12in travel with 2 bypass tubes,there kings,shouldve ran swayaways like the front,same travel but shorter overall length, but the same shock from them was 100$more per shock.
