Mike74Bronco
I just got the Bronco back from the shop and it passed safety and emissions! Now that I've got it back on the road for the first time in 11 years I need help getting everything running right. Here are my concerns so far:
1) What should the alternator gauge read under normal operating conditions. Mine reads just barely above 0. Is this normal? Is there something I can do to test the gauge before suspecting alternator problems?
2) When I am driving the bronco (it is moving) my oil pressure gauge reads around 40, but whenever I stop at a light the guage slowly drifts down to very close to 0 and then it drifts back up to 40 once I get moving again.
3) The engine idles rougher than I would like it to. When I stop at a light it sounds like it wants to die, but it never does. I've played with the idle screws a little bit and the drivers side is about 2 turns out to get the smoothest idle. The passengers side screw I can't get to make much difference, but it is about 2 turns out as well.
Here's some numbers on the engine if you see anything to be concerned about let me know. I have a 302 with a rebuilt 2150 carb.
Idle Speed: 650 RPM
Timing: 6 BTDC
Manifold vacuum at idle: 12 - 13 inHg
Compression Test (1 - 8): 130, 122, 120, 110, 130, 110, 112, 110
Emission Results:
15 MPH (1294 RPM) CO2-11.7 O2-0.8 HC-299 CO-4.23 NO-492
25 MPH (1304 RPM) CO2-11.5 O2-0.9 HC-309 CO-4.57 NO-384
Thanks to everyone for their help. I wouldn't have gotten the Bronco this far without ya!
Idle Speed: 650 RPM
Timing: 6 BTDC
Emission Results:
