Need picture of BCB 2 into 1 exhaust routing with a ZF
RedLeg0811
Maltby, WA
If you have a picture of of how you routed the two into one exhaust with a ZF and a BCB cross member it would be much aperciated. I had the 2 into 1 before on my old 3 speed, but it doesn't quite fit so I pulled apart the welds. For people that do have this setup and don't have a picture, did you run the pipes going into the muffler both above the cross memeber or one above and one below?
Martin
marklc
Bump!! I'd be interested in seeing that as I am getting close to doing the same thing.
Desert Thrasher
I made the bc exhaust work, but its not pretty. One tube goes above the crossmember and the other below. However it doesnt fit right. I had to dent in the lower tube a bit to work and also ended up using flex exhaust tube to connect with the muffler. I will post a pic later today if wanted. Redoing the exhaust is on my eventual to do list. But it works for now.
Sent from my MB860 using Tapatalk 2
rguest3
BC Broncos has pretty good pictures on their website of the installed exhaust system.
I was thinking of installing their system as well, but from all the mods needed to make it work, it may not be worth it. I may just use similar headers (less expensive) my favorite muffler and have the exhaust shop do the rest.
RedLeg0811
RedLeg0811
Maltby, WA
I saw pictures of it put together, but not any in a bronco. could you link me to those pictures?
Martin
AZ69EB
I bought the BC ZF complete kit, BC Sorties, and the BC 2 into 1 exhaust when I installed my ZF.
What I found was shipping the exhaust kit back and forth is far more expensive than having a local exhaust shop do the job right the first time. Plus, your exhaust will fit your bronco perfectly.
I also had the exhaust shop add an extra flag to make it a two-piece exhaust set up. This is a nice feature to aid in removing the exhaust when you need to change a clutch or something. In addition to that, I had my exhaust ceramic-coated black to reduce the heat transfer.
Good luck!
RedLeg0811
RedLeg0811
Maltby, WA
Hey Thanks for the pictures. I don't know why I didn't think of making a flange. Well good thing I have not started to rewelding everything because I am using that.
Martin
