A while back i had a problem starting the Bronco. To make a long story short, I had to jump the starter relay to get it running. Well, as I was completing my new dash install, I noticed a cut wire under the dash an I traced it back to the neutral safety switch - this explains why I couldn't start the Bronco by using the key. I rewired the electrical system when I first installed the EFI setup using the attached diagram and all worked well. But now, I am having trouble figuring out just where to reattch the neutral safety switch wire. If you look at the diagram. blue/red wire runs from the key to the junction block and out to the NS switch - but where does it go from there?
