I've never been to the point where I'm thinking about letting the bronco sit broken for a while. I swapped 85 mustang heads from a running driving bronco onto my 302 after I had enough issues with my old 71 torino heads and not a lot of money to throw at it. I installed them what I believed to be correctly (super clean surfaces, gaskets facing the correct direction, torqued using the torque sequence in my Chiltons manual ) and during the first drive I got overheating issues, radiator half drained with milkshake. The Bronco never had overheating issues before I swapped heads.
After inspecting the intake gasket, it looked like my old style water passage on my intake wasn't sealing correctly and I assumed it was what was letting all of the coolant into the oil... so I ordered another intake, thermostat and gasket set.
I installed them this weekend and took it for a drive today, it held temp great after I bled the system again (185-195ish) and then I checked the radiator and oil after it cooled down... milkshake again and the radiator was half drained. When I was bleeding the system before I drove it I had filled the system with a no spill funnel, modulating the throttle and got most of the bubbles out but they never really stopped.
My guess is that I did something wrong when installing the head gaskets. I don't think its the heads fault, I think I may have had some dirt or foreign debris contaminate the mating surfaces between my heads, block and new felpro head gaskets. I know I need to do a leak down to find out which head its from (maybe both, I don't know). But I'm so mad I'm just going to let it sit. Wasted another oil change, coolant, gaskets, time, money... I'm tired. Not really asking for help, just needed to vent.
Sent from my SM-G981V using Tapatalk
