fromme
I bought this Bronco:
http://classicbroncos.com/forums/showthread.php?t=147485
Drove down to NC and he accepted my offer. It is a very solid truck, but still I knew a couple things would need attention. It is old after all. The big things I noticed were the front pinion yoke was very loose, and the timing was so far off it was detonating terribly from 3,000 rpm and on, and it wouldn't idle well at all.
I've enjoyed it and it was easy to fix the idle, just clean up some stuff (IAC, MAF etc.). I pulled the front cover and there about 10 broken teeth on the ring gear and all the bearings are shot. The differential moves side to side and the pinion in and out. There's about 10 different patterns on the ring gear. %) So somebody knew it was broke.
The timing was set at 36 degrees with spout out! No wonder it detonates. Problem is, the damage was already done and a head gasket was shot. I don't know if he didn't know how to set timing and damaged this, or if it was damaged and he advanced the timing so far to keep it running half way decent.
So it threw me for a few unexpected loops, hopefully after I get this back together I can enjoy it for a bit. I guess you just never know, hard to know about things you can't see that are internal. I'll get it fixed up. At least the original builder of this thing did a very clean install!
![DSC02356.jpg](http://i47.photobucket.com/albums/f193/kfromme/71%20EB/DSC02356.jpg)
![DSC02357.jpg](http://i47.photobucket.com/albums/f193/kfromme/71%20EB/DSC02357.jpg)
![DSC02358.jpg](http://i47.photobucket.com/albums/f193/kfromme/71%20EB/DSC02358.jpg)
![DSC02359.jpg](http://i47.photobucket.com/albums/f193/kfromme/71%20EB/DSC02359.jpg)
![359373878.jpg](http://i47.photobucket.com/albums/f193/kfromme/71%20EB/359373878.jpg)
![mybronco007.jpg](http://i47.photobucket.com/albums/f193/kfromme/71%20EB/mybronco007.jpg)
![mybronco008.jpg](http://i47.photobucket.com/albums/f193/kfromme/71%20EB/mybronco008.jpg)
![mybronco012.jpg](http://i47.photobucket.com/albums/f193/kfromme/71%20EB/mybronco012.jpg)
