Hey all,
I've owned a '70 Bronco since 1996. It was a daily driver for nearly 6 years. I'm almost done with an extensive rebuild and need some help for a push button ignition system.
Here's what I'm trying to do....
I'm trying to do an ignition system with an 'on-off' key switch that will simply complete the circuit to a push button starter. I'd like to have the 'accessory' position of the typical ignition switch controlled by a regular toggle switch. The key'd switch will simply allow the push button switch to juice the starter.
My perfect idea is to get in, put the key in and turn it to complete the circuit. Then flip the accessory switch to complete all necessory circuits. then hit the button and fire it up.
Has anyone done anything like this? I've got a key'd switch and a push button limit switch I've been tinkering with and I've really been pulling my hair out to get it to work. I'd buy you a cold beer and a hot cup of coffee if you've got a wiring diagram for this set up.
Thanks, and I've really been enjoying lurking here. Finally joined!
Luke
Luke
