First up new drivers side front fender. I'm showing you in the first two pic why it's $70. The first pic shows some imperfections in the finish. You will be sanding and painting anyway. Pic 2, same fender has small bend which would be cut out if you are installing flares. Freight estimate $35-70
SOLD Next new drivers side front fender. Pic show where spot weld is not welded. This is
whatever that means. $100 Freight estimate $35-70
SOLD Next, no pic. I have a pass side front fender. The tag on it said it had a dent. It took me two minutes looking it over to find it at the back edge where it bolts to the door post. I could smack it with a hammer and you would never know there was a dent. It's in the flange that bolts to the door post not the part you see installed. $120 Freight estimate $35-70
Up next aluminum diamond plate rocker panel covers. Brand unknown other than they are not WH. New, you supply your own screws. $50
New stock height progressive rate coils. Free dust. $80
Last two pics, pass side lower quarter panel. $60
For quotes I need zip. CA only 8% tax. First come first served. email sales@wildhorses4x4.com or call 209-943-0991
