That welder is just not set up for body panels. If you go to .030 wire and the lowest setting, you might get the floor pans in. You need to overlap and rosett/plug weld the pan's. I don't think you'll ever butt weld with it, but forget the bead and spot weld it, spacing them apart say a foot apart and then go back in between over and over till done making sure to allow welds to cool. You can back up your welds with a piece of copper and increase your chances of not burning thru. Google some welding sites for tips and technique. Good luck.
