- Oct 11, 2007
- 442
I’m about to start my nine inch re gear to 4:56 and I have a question about setting the pinion preload. I’m going to try to use a crush sleeve because that’s what I have in my kit. Everything I’ve read says to set preload without the pinion seal in but how does that work with a crush sleeve? Because I've also read your not suppose to remove the pinion nut and then reuse the crush sleeve. I understand if I had a solid spacer this wouldn’t be an issue.
