https://tpdhifi.com/products/1966-1977-bronco-kick-panels-morel-virtus-nano-carbon-full-kit
1st generation Ford Bronco presents many challenges when it comes to installing a high quality audio system. The factory speaker location is limited to a single small dash speaker, the limited footwell space and parking brake limit kick panel options and everything has to be able to handle the elements of an open top vehicle. Born out of years of experience building custom Broncos, TPD HiFI has the answer! Our audio kit combines the legendary Morel Virtus Carbon Nano 6 inch speaker with TPD’s revolutionary shallow kick panel for a total depth of 1.5” allowing plenty of clearance for your feet and a functional parking brake. Then we add a 4-channel Musway amplifier with built in DSP and a Musway powered 7 inch subwoofer for a 6-channel, audiophile quality, sound system that is 100% designed around your classic Bronco. Not familiar with tuning DSPs, we preload our base tune into the amplifier so you can fine tune with your head unit’s audio settings. In addition, we include mounting brackets for the amp and powered subwoofer that allows them to be mounted out of sight. To top it off we include a pre-wired harness and instructions. Everything you need to install the system is included except for your source (head unit). Want to have a smooth dash with no head unit? Our system has built in Bluetooth connectivity and can also be used as a stand-alone system. For maximum output and sound quality we do recommend a quality head unit with RCA outputs of 2-5 volts.
To learn more watch our in depth video here:
- TPD HiFi
Call or Text Us: (918) 992-6292
Manufactured here in Broken Arrow, OK USA
![6473 Bronco Black+Kit.jpg 6473 Bronco Black+Kit.jpg](https://classicbroncos.com/forums/data/attachments/926/926108-b7204f608b8974e35b21f8f3ba7a7546.jpg)
- TPD HiFi
