easton68
Hey there just have a ?. I swapped out my original 3 spd for a NP 435. At first the engine would not crank over unless the clutch was pushed in. I pulled the top cover off of the tranny and found that the cover was not on correctly and was binding up the gears. Once the cover was off I reached in and slid the granny gear toward the back about a half inch and it fired right up. Is this unusual or did I just have the cover on wrong? When I do that everything seems good but once I install the cover again it binds up again to where it will not crank over unless the clutch is in. Oh also when the cover is on the trans the shifter is in the neutral position but the trans is obviously not because I can't turn the rear yoke on the T-case. Any help would be great and thankyou. I have heard the NP435 top cover can be a bit of a pain, if so can anyone explain the best way to put it on?
