jperry1290
- Jul 1, 2010
- 916
I pulled my NP435 because it felt like the clutch was slipping and the thing was leaking like a sieve. I replaced the seals and installed a new clutch. The gears looked good.
Problem 1:
I reinstalled everything that came out. Now I cant shift into 1st or 3rd because the shifter is blocked by the dash. It slightly hit the dash before I removed it but I was always able to get it into gear without issue. I lowered the crossmember about 1in with a jack and disconnected the driveshaft. I was able to shift it into all gears with the engine off and running. Why would the throw to 1st and 3rd be longer now? (I do not have a body lift)
Problem 2:
With everything installed I tried driving down the street in 2nd. The clutch grabs, but as I increase the throttle it acts like it did before and seems to not be grabbing all the way. I have not adjusted the shift linkage yet as I am waiting for responses.
Problem 1:
Problem 2:
