Is the only difference in the 2wd and 4wd trans itself, the mounting bolt pattern?
I have a 4wd trans and access to an advance adapter, along with the spud shaft. But the bolt patterns don’t line up because of the A pattern I have and the adapter is the square pattern. Are all the internals the same? Could I just drill holes in the flange to match my pattern? Would adding holes in the flange weaken it? Or even tap new holes in my case?I’ve got the machining end of it covered.
Or is there more to it? And yes this is to bolt up to my Dana 20. Thanks much, Jason.
