O RING OR NOT ? ( water neck )
horseman
Going to replace my thermostat ( stuck ) and might as well get the water neck while im at it. Which one should I get ford racing has a chrome one with and with-out o-ring . Also any install tips with the o ring Ive never installed one w/O-ring
bluebroncodrive
I would stick to a gasket its ez to replace and you can find it at any parts house, just my 2 cents ;D
mtkawboy
Billings Mt
Do not put a chrome one without an O-ring, it will leak. Kind of depends if your stock one is corroded up or not which way to go. I like the stock ones so I can glue the gasket down and glue the thermosat in it so it doesnt fall out of place as Im putting it in.
krunchytaco
Carlsbad,CA
Ive been running a chrome water neck with a rubber O-ring for about 4 years and havent had a leak yet..
I just lightly sanded down the contact area where the hose attachment is..
71_Sport
If it works properly and is mostly clean, don't give a rats ass what color it is or what finish it has.
astark
Bronco God
O'Reilly Auto Parts has them for less than eight bucks, the very same made in China carried by NAPA for two dollars more. They have a pipe plug that screws into the top, I used yellow pipe thread tape on. Do not over tighten that plug or you will crack the housing, they are cheaply made. The gasket that comes with them can be upgraded to a kind of fuzzy on one side with peel off sticky on the other, it worked well for me with no sealant.
Anyway, just thought I would throw that out there.
bronco977
Bakersfield
I put one of those cheesey chrome Pep Boys housings on, and it had the o-ring. Leaked like mad on a new Edelbrock manifold. I made a thick gasket for it and, in addition to the o-ring, that seems to have solved the issue.
BUCKETOBOLTS
Salisbury, NC
I've used them before and as a matter of fact I have one on my 393W now. I've never had any trouble with them. I just use some vasalene to stick the thermostat in place so that it doesn't slip out of place. Then don't over torque the bolts.
SteveL
Huge chevy guy
Hawthorne ca
If you run a chrome one, especially one of the cheap ones make sure the bottom is flat. More often than not the bottom surface of those do not mate up flat on the block and leak. It happened to me and 2 of my friends afterward, thought we would upgrade to the cool chrom waterneck. All 3 of em were warped.
astark
Bronco God
These ones I mentioned above are not chrome by the way, just plain Jane's.
And when upgrading to the better gasket, put the thermostat inside the housing first, then apply the peel off sticky side of the gasket to the housing and it holds the thermostat in place.
