As the title says...
It looks ugly but no leaks anywhere. Includes skid plate, straps, J-hooks, front bracket (retainer for straps), filler neck with good stainless steel cap, sender, sender wiring harness.
Sender is accurate, though filter sock on inlet is long gone (I used an inline filter). I modified the sender by adding a return line for EFI, silver-soldered in place. Fittings on lines are -6AN, since that's how the fuel system in my EB is plumbed; I can include -6AN to 3/8" hose barb fittings if desired.
To use this, assuming you don't have an aux tank already, you'll need the rubber hose from filler to tank, a fuel tank selector valve, a dash switch to select senders and a wire to the sender from the switch. The Bronco houses all sell the parts.
I removed it because I wanted a yet-larger capacity aux tank (this one holds about 9 gallons) for the way I travel with my Bronco. In my case, too much fuel capacity is almost enough.
Pay me actual cost of shipping plus 10 bucks for my troubles and it's yours. Shipping will be via FedEx Ground.
![i-2CMKs8g-L.jpg](https://photos.smugmug.com/photos/i-2CMKs8g/0/0d67df61/L/i-2CMKs8g-L.jpg)
![i-gHMKJWC-L.jpg](https://photos.smugmug.com/photos/i-gHMKJWC/0/c89e4060/L/i-gHMKJWC-L.jpg)
