Offroad Lights - Lightforce XGT
JaxLax
Jacksonville, FL
everyone i have ever seen is a piece of beauty. Pattern and output is amazing... never seen a bad review....
They are just BIG $$$$$$ those are the lower end of them @ $169 PER LIGHT! :eek:
I mean, if you want serious BLING....try the 240 HID Blitz a mere $750 per light :eek: :eek: :eek: :eek: :eek:
Case
you might run into problems with the HID's if you ever do any trail rides in the woods. The intense light might ignite trees and brush. :) ;)
RRRAAAYYY2
Brantford, Ontario
Just thought I would get in before instead of after. These lights could put an extra 10amps of draw on your electrical system, each. So 2 of them will add an extra 20amps of load, at idle. Most stock Ford ext. alternators only put out 25-35amps at idle.
My point is that if you are running a stock externally regulated alternator right now. You are going to need to put a high output alternator on your wish list as well. Or you will run into voltage drop problems at idle, which effects your performance and the life span of everything that is powered by electricity on your truck, which includes those expensive new lights.
Those lights definitely look good though. Been thinking of a moose bumper for my burbon, they would definitely make for good finishing touches to it.
R
rob wilson
Flagstaff, AZ
Ray,
Thanks for the thoughts. I had not really considered the draw and it's impact on the system. Think I have it covered though as my soon to be installed 347 has a 160 Amp single wire Alt.
Good catch though.
R
rob wilson
Flagstaff, AZ
Well, Santa came through (helps when you provide the wife with a link to the site to order)
Got the XGT's. First impression - Whoa, those are BIGGER than I thought. So, have to hook one up to a spare battery and see what it does. WHOAAA, talk about light, these things are one step under a laser beam. Very tight beam that goes forever..... I had assumed that the snap on filters offered for the 240's were also available for the XGT's but found that is not the case. Means they are pencil beams only.
Bad news is they are just tooo big for the front of my Bronco. I'll be exchanging them for the 170's which are about 2" smaller in diameter.
Anyone looking for BIG LIGHT couldn't go wrong with these.
GRIZZLY
Lakewood, CA
The 170's look nice too. I got a set of the 240's from my wife(Santa). Definitely big. I'll need to fab different mounts. One advantage of the 240 is they have a variable beam like a mag light. Same issue with the alternator. A friend of mine is giving me a deal on a 160 amp. I got a set of green covers to go over them so if you hear reports of a low flying UFO out in the desert it's just me.... ;D
