On-board air compressor oil system.
TonyPDX
I am looking for comments on this. Here is what I have so far: factory Ford compressor, oil/water seperator taped for a return line to the pump inlet. The fitting on the pump inlet is a needle valve so I can adjust the oil return flow. I tapped the seperator part way up to allow the water to settle out at the bottom. Anyone tried this?
Tony
airman
I am not trying to rain on the parade but.......2 potential problems I see are:
the water will accumulate in the bootom but so will the oil and I assume the retun line is to introduce oil back to the inlet of the compressor.
The return line is common with all compression as far as I can see. Air wants to equalize in pressure andfollows the path of least resistance. I don't see why the compressed air will want to go anywhere but back to the inlet?
I have thougt about something similar myself in the past but was planning to have the return to inlet be the discharge from a float drain.
I also doubt that you will see much water that close to the discharge. After heat of compressionthe air will be quite hot and it will require cooling to get any consdensation.
Unless there is something tricky about that reurn line I dont think it will work and even if it does it will need to be full of oil to that point before any will go back to the inlet.
Jeff in AZ
airman
I just saw the part about the needle valve. It may work but the oil level will still have to be as high as where you tapped the housing of the filter. I think the bottom would have been better but oh well.
If the needle valve cannot be adjusted right you may be able to do it with an orifice fitting. I might also recommend using as small of tubing as you can find for the return to assist the flow of oil.
Jeff in AZ
hudson's74
Port Gibson, Ms.
You might try a dryer like on a refrigration compressor as i removes water and lets oil flow through Like on a commerical cooler. Might work don't know?
TonyPDX
TonyPDX
Hey Jeff, thanks for the input, I was wondering how much condesate I would capture that close to the compressor outlet. I figure my duty cylce on the compressor will be rather short 90% of the time so it shouldn't get very hot.
My first thought was to go straight off the bottom drain (it certinaly would be cheaper and easier), but I was a little worried about the water in the system and I wanted an oil "reservoir". I am planning on keeping a few ounces of oil in the seperator to feed the compressor.
The smaller return line to promote oil flow is a good idea, I will see if I can find smaller fittings.
Thanks, Tony
airman
This is not a good idea for any refrigerated heat exchange because the oil will build up on the inside of the tubes and start to insulate.
Tony, I would find a filter with a clear bowl so I could watch what is being collected and then if it becomes too much water (which I doubt) then drain and refill the bowl.
The heat that I refer to is made by compression and not friction and will be there as soon as you compress air. You may not be able to feel it on the equipment by hand until it conducts through the case but it is there. I don't think you will find water until you get farther away. I think it will still be vapor at that filter.
Good luck
Jeff
elemetal
Oakland, CA
Hey Tony, how much more stuff are you going to cram in that engine compartment? ;D Two things I thought of with this: airman is right, the condensation comes from pressurizing the air (higher pressure means less ability to hold moisture and temp increase)not friction so time on doesn't have much to do with it. I'd feel better about the return line if it was actually coming from an oil pot rather than skimming off the top of a mix. Is it possible/practical to put a small collector outside of the separator before it goes back to the intake?
TonyPDX
TonyPDX
Yeah, I know I am getting too much stuff in the engine compartment... But it is better than before I started this rebuild. The Seperator does have a sight glass on it so I can see how much oil or water is in it. The plan is to keep the oil level above the return line so it really shouldn't matter that it is not on the bottom of the seperator. If no water shows up after I have put some time on the system I may move it to the bottom of the seperator... The hard part is going to be how much return flow to allow with the needle valve.
Tony
