broncosbybart
- Mar 13, 2002
- 2,644
Parting with some stuff I was gathering for a Dana 60 front axle swap. Ended up buying a Bronco with a Dynatrac HP D60 front axle under it already. So, here goes.
ARB RD36 35 spline air locker. It is BRAND NEW in the box! Never installed. 4.10 and down numerically. Perfect for your Ford HP 60 front axle, as they all use the thick gears for the steeper ratios.
This is the older and more desirable design. $1000 plus the ride, if you need it shipped.
1 set of new 5.38 high pinion Dana 60 gears from a 78-79 F250 housing but will work in all year HP60 housings. Gears were installed on an open carrier and set up, but never run in the axle. SOLD
1 set of standard Dana 4.10 ratio HP60 gears. No pics, but I can take some if need be. $75.
1 pair of welded wedges installed and cut back off of a Dana 60. These allow use of the stock Ford radius arms without any shimming or modification of the radius arms. $50
1 new SOLID brand differential cover with hardware. $75. PENDING
1 pair of used 8x6.5 lug Dana 60 rear brake rotors off of a F-350 van. $40/pair
1 new Dana 60 master install kit with KOYO bearings. $80
