- Jul 31, 2001
- 8,998
ORI mounting- 1" of shaft showing on setup you STILL need to allow 1" compression...
Update** --I found that this one source was incorrect... so since I can't figure out how to delete the post just remember that you will always have just under an inch of chrome shaft exposed even under full compression
SO, I have bent up some 1.5" x .188" DOM for upper ORI tube mounts and have read and been told that you obviously set the distance btw upper and lower at full compression and then you tune them...
...but I just read that you STILL need to allow one MORE inch of compression because the last inch of exposed shaft at full compression will now be compressed when the last 1" of bumpstop is used...
Anybody else offer some more info on this?
