marty
so yesterday i bought a painless wiring cirkit boss fuse panel. it is a total of 7 fuses and a relay. 4 fuses are switched power off the igntion switch and 3 are constant hot. this panel came with 7 fuses that are rated at 20 amps each. it also has a main power lead which feeds the 12 volt supply and the relay which looks to me to be a 12 guage wire. they also supply a cicuit breaker for the main power protection which is rated for 30 amps. to me this panel is extremely under rated. if i used 3 circuits drawing current of about 10 amps each i am already pulling to much current then the panel can handle. so i proceeded to call the companies tech line. i get a guy in the phone and i explain the situtation to him. he immediately tells me the circuit breaker is the wrong one. well i explained to him i did not even take it out of the wrapper yet. so he looks the panel up on his computer to see what this panel comes with and he agrees with me fully about the load ratings and the wire guage size for the main power supply. i told him i am afraid to use this panel and he tells me if i am afraid then not to use it. i asked him what should i do then and he tells me their are thousands of these panels out there and not a problem that he knows of. how can a company sell stuff like this. thank goodness i don't need the panel for anything of substantle amperage. but i thought i would let some of you guys that may not know about wiring and how the wire guage size over a certain distance should meet certain standards plus how fuse ratings should be rated properly. i would not recommend using any of painless wirings complete wiring systems after seeing and talking to the company directly and how they change their story. they just don't seem like a stand up comapny to me. thanks for letting me vent here and i am sorry for the long post i just would not like to see a guy finish off a nice restoration only to watch it go on fire due to poor workmanship from this company.
