Patina preservation with linsing oil problems?
rjrobin2002
I like the results of linsing oil rub on original paint with some surface showing through.
My question is if I get tired of it, will the oil absorbed in the base material and paint cause future adhesion issues if I decided to prime and paint it?
And how often do they require reapplying linsing oil?
Quick & Dirty
Linseed oil can be softened/dissolved and removed with turpentine. Paint stripper will do the job as well.
spap
Never heard of that, doesn’t the oil attract a lot of dust and dirt
Something new everyday
ugly74
Bronco abuser
I don’t think I’d be rubbing it down with Linseed oil. Unless you have a body made of wood!
rjrobin2002
rjrobin2002
Here is a comparison before and after, obviously you could make it a little duller by wiping less on.
gnpenning
Bronco Slave
Linseed oil cut with some mineral spirits is common for metal preservation. From vices to vehicles. The mineral spirits helps it dry faster. Besure to spread the rags out in a safe place to dry. I'm aware of some who paint over it at a later date. What little I've played with it I like the results.
Check in the free parking section as this has had some discussion for patina.
Edit: you posted while I was typing. I think that looks good. Is that a example you found or yours?
okie4570
NW OK
The few I've seen looked great except for one, and it was a lighter color. The darker color patina paint looked great.
Yeller
Rogers County Oklahoma
Once it’s dry it’s paintable, the place I buy my fencing materials from recommend sealing bare metal with 2 coats of linseed oil prior to painting. I’ve never done it and probably should try it. It lasts a really long time on my GMC Just did it for the second time in 3 years and drive it everyday. Just park it in the sun to dry it will bake dry in 24-48 hours in the sun. It sure makes the rusty metal easier to wash and keeps what paint is there there instead of continuing to disappear
rjrobin2002
rjrobin2002
Good to hear it last a few years.
