68 Broncoholic
OK its getting late and I'm almost done with this project. Over the weekend and today (took the day off) I stretched the rear D70 axle back 4". I also installed the Cage 5.5" lift with the extended radius arms on the HPD60. These are the weld on axle brackets. I had to make a side bracket off the weld on bracket to help bring the coils under the bronco so they are not so bowed. I also pushed the front 1" forward. Tomorrow I'll get photos of the truck outside to show the overall length gain. The garage needs lighting bad and I haven't cut the wheel wells out yet. I think the camera is having some issues but htis is what I can show I guess...
First photo shows how far off the stock shock mount is sitting at rest (5.5" lift). I'll grind off the mount and twist it more verticle or even 1:00 to help down travel.
This shows the plate on the front hanger. I already painted it black so ts tough to see. There was no way to clamp this bracker to the frame so I added the center brace so I could clamp and tap into position.
Rear hanger/plate.
Rear hanger at end of frame.
Front coil with side bracket
Cage weld on bracket.
Raised trac bar bracket not yet finished. I'm using my old trac bar for now until I get a longer one. Otherwise the truck wan't to tip over without...%)
Another photo...
Rear hanger/plate.
Another photo...
