Kyle.malone
OK heres the lowdown:
91 block. built 331 stroker - 8.5:1 compression, eagle crank 4340. Eagle H beam rods, JE pistons, Moly rings (gapped for nitrous but wont use) celvite main/rod bearings, ported edelbrock victor jr air gap, new timing chain set, high volume oil pump, felpro mls gaskets, aftermarket balancer, ARP bolts used for everything, 1.6 roller rockers, ported world products heads, aluminum valve cover, CSR polished electric water pump, and Canton 7 qt oil pan.
1st thing to be changed will be the valve covers, oil pan, and the water pump. This motor is a fresh rebuild with 0 miles on it. I picked it up for $2100. I'm gonna remove the timing cover to find out the cam in the motor but it is matched to the motor. I can't wait to get this thing in. I will be putting on a 750cfm Demon card with extensions in the jets for offroading.. ;D
My 71 block that I had completly rebuilt with all new everything except for the crank and rods will be up for sale soon. Its' funny howe I have more in the rebuild than the buy cause someone got bored.
