Mine is the orange one in EOTH's post. The doors are the Galen 2-peice doors and they are the design basis for the Bestop doors - they fit the same. The Bestop ones do have some improvements like bigger hinges, better latch connection on the insert, and straps to tie-up the windows when rolled down.
I like them a lot. They work fine with a hard top but will never seal as well as a stock door. I don't mind this since mine is mainly a trail rig. I do drive some in the winter and have driven it over 200 miles in the snow for MEB's Snow Run. My back is open and I have a homemade windjammer on the roll bar that does a reasonable job of keeping the heat in. The doors do suck out at the top at higher speeds (~60 mph and higher). When it's really cold, the worst air leak is at the lower back part of the insert - a constant cold blast will hit your thigh. After your thigh is numb you won't even notice it! ;D
