Pictures of aftermarket aluminum valve covers and EFI please
rjrobin2002
I am wanting to run some aftermarket valve covers on an Explorer 5.0, but they most all come with a hole on each cover, as carbed engines use one hole for PVC and the other for a breather oil cap. EFI requires all air entering engine metered right. So how have yall plugged the extra on some like these?
Any pictures of ones that worked for you would be appreciated. The ole 1996 roller 351 with lightning lower and Explorer EFI is almost ready.
904Bronco
San Martin, CA
Maybe an Aluminum set from a 88-93 Mustang, my Brother polished a set up.
They are a tad taller than the stamped steel Explorer ones. But closed on Driver's side.
74 Bronco Billy
You can buy rubber plugs that will close the fill tubes. That would give you more options
Sent from my SAMSUNG-SM-G930A using Tapatalk
