BroncoPoor
- Dec 14, 2009
- 174
Which pitman arm pullers are you using? Most of the units i have found are not large enough to fit around the arm.
When I ran into that same problem, I took my 4 inch grinder and ground a little off each side of the pitman arm just enough so that the puller would fit on it.
I bought a large 2-jaw puller at Sears when I did mine. Worked very nice.
2 jaw puller cranked down as much as I could. Heat on the pitman arm. BFH and a drift from above onto the pitman arm.
I use a large 3 jaw gear puller and wire the jaws together. Works great and I can use it for other stuff too unlike a dedicated pitman arm puller.
You don't need much heat. Your trying to only heat the arm.never used heat, too worried about the seals inside the box. i've used a BFH and smacked it on top and it comes off.
