PaulW 72
Here is my proper 3 link. In the final configuration it has a ram assist
The fab was done by Glen Straightiff in El Cajon CA several years back.
Other things to notice are large rod ends and a pretty fat trackbar.
Very adjustable setup, but the rod ends are rotated for link lengths. Even with that it was still less costly for an alignment than a Jeep parallel link setup.
Final setup is 0 deg toe and 10deg caster. Drives great - hands off on the highway at speed.
Question about steering radius. Yes, it is limited with the adjustment screw with slight adjustment due to the 13.5" wide BFG Baja tires tires. Your result will depend?
Bushings ?? No way - That is a Jeep thing.
Pictures:
First pic the final. Above the aluminum skid find a Steering cooler and the stat for the trans cooler
Middle is the 3 link before the ram was added
Right hand pic is a view from the rear showing the rear arms.
PaulW This Bronco is available May 2021
