power steering pump/ hoses replace.
scott forbes
Working on my '73 302 and decided to replace the whole system but for the in line OEM cooler, which will stay where it is.
I'd like all 3 hoses and the correct pump, the latter of which seems plentiful. Any sources for the 3 correct hoses either as a kit, or each would be appreciated. It's that 3rd. hose that has me stumped.
I'm an OEM guy, so no GM looking parts will be utilized under this hood. Thanks guys, Scott
thegreatjustino
Red Head Grease Monkey
Stockton, CA
If you're talking about correct looking fittings and length, good luck.
If you simply want parts that fit, the pressure hose is available at any local auto part store, and the return lines are just low pressure lines with hose clamps that you can buy by the foot.
73azbronco
custom hoses at a local hose place like hose advantage or parker hose. Usually no more than store bought. Usually same day, And you know they will fit.
I say that, but even Parker, a national chain, stopped carrying the power steering fittings, they sent me to a guy down a street I wouldn't walk alone in downtown PHX, but he did it in an hour. Tells you where major suppliers are going, not supporting 50 year old fittings... Yes, I think summit had fittings, week to get them, another 4 hour drive, yada yada.
Shimmy
1977 Bronco
Maple Valley
i recently redid my power steering/hydroboost hoses using Earl's hose and fittings. They look great and were very easy to work with.
ntsqd
heratic car camper
Upper SoKA
Sounds like the PO wants a period correct looking restoration, not merely just a functional PS system. That's a whole level harder to do, even with the plethora of restoration parts becoming available.
For functional, a Saginaw pump and a conversion to -6AN/JIC hoses & fittings gets my vote. Converting my '96 FSB to the E-150/250/350 Van Saginaw pump and bracket finally eliminated the Ford PS pump whine.
