casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
I finally finished my conversion from stock power steering to a Rock crawler 4x4x2 Box last night and started the process of getting the air out. I fired it up and promptly dumped all of the fluid on the garage floor. It would appear that when you have a hydroboost you should remember to hook up both return lines. Got that taken care of and tried again. Everything works fine and I drove it around for a few hours so I'm pretty sure all the air is out. The problem is that the pump whines like crazy! It was quiet as could be with the stock steering box. I'm thinking that when I ran the fluid out of it I damaged something inside. The pump is a dual return saginaw from a 197? who knows what. Any suggestions? I could rebuild it or go to the junk yard and get a "New" one but it would be nice to fix it in place. Could I still have air in it? It is of course worse when its all the way to the lock and it screams pretty good when I jam on the brakes because of the Hydroboost.
Also, what gets Power steering fluid / ATF out of concrete? I got the big mess cleaned up but the garage floor is pretty stained.
