Protofab skid plate
vainglorious
Long time reader, first time poster.
Finally getting around to my 68 build and ran into an issue on the gas tank install. I picked up a protofab efi tank and skid plate years back and they didn't come with install notes. Checked their website and couldn't find anything on the skid plate. Tried emailing them as well, but they have not responded.
Does anyone have experience installing their skid plate? Do you use the existing holes on the side of the frame from where the original strap and j hook went? Doing so would mean drilling/enlarging the existing holes and the j hooks would be canted and not sit flush with the skid plate.
My 68 did not have a factory skid plate, therefore there are no holes on the bottom of the frame. Would this skid plate necessitate drilling holes and using their provided j hooks to sit inside the frame from the bottom?
Here is a link to the protofab skid plate I am referring to.
https://protofab4x4.com/products/add-on-23-gallon-fuel-tank-skid-plate
Thanks.
Shimmy
1977 Bronco
Maple Valley
have you mocked it up to see how it aligns with any existing holes, etc? it's hard to see from their pics but i think a see a candy cane bolt? mocking it up and posting pics here would help us.
.94 OR
Willamette Valley, OR
In the picture where the tank is mounted, it looks like it has a strap using a J-bolt much like stock tank mounting.
Does the skid plate replace the use of the strap and use the J-bolt on each side to hold both the tank and the plate in place?
Kind of a hassle if you want to drop the skid plate for cleaning in the future since the tank would be loose then.
V
vainglorious
They do utilize a candy cane bolt. I've mocked it up and it would align with the original holes on the sides of the frame where the original strap and j hook would go. Would need to enlarge those holes to fit the candy cane bolts. If done this way, the nuts on the candy cane bolts would not sit flush with the skid plate mount and be quite canted. Not sure if that is correct as it would be the only thing holding the plate and gas tank in place.
Mine did not have an original skid plate, therefore there are no holes on the bottom of the frame where one would have been attached.
V
vainglorious
Per the description of the skid plate on their website, it does say that it replaces the use of the original strap and j bolt.
I'm more or less looking for confirmation from someone who has installed it, that it does use the original holes, just enlarged, and send it that way.
Shimmy
1977 Bronco
Maple Valley
from what i've seen some folks need to enlarge the original j bolt opening to accommodate aftermarket setups. no issues. it's also common to see those i bolts canted and not flush. looks like washers are used to address this. you can see this WH skid plate mount is actually at an angle.
.94 OR
Sure looks like the support on the plate side should be mounted up higher so the J-bolt could be shorter keeping it away from the exhaust.
V
vainglorious
Thanks for the insight. I'll move forward with enlarging the holes and sending it that way. The Wild Horses skid plate angles so the bolts sit flush with the mount, which would be ideal.
The proto fab is 3/16" and won't be bending any time soon. That leaves the bolts to be canted and not sitting flush with the mount on the plate. I think that's the way it has to be though.
