Bronco69Sport
So I finally finished up my PSC full hydro, along with my Got Propane, Hood scoop, and top protectors. Pics to follow... ;D Love the PSC. I have not had a chance to test the propane setup. I did switch to a 195 high flow thermostat, boss 429 hood scoop, and a flow cooler water pump to cool my engine. and also installed a new fan shroud... The howe racing radiator, and cut almost everything cut out under the scoop. along with my wheel wells. Just need to add a cooler to the psc setup.
I ended up using 9/16 grade 8 bolts through the existing holes for my hard top, marked them out, drilled, set into place, and then drilled the lower ones through the panel. Bolted them into place... that way I can quickly take it off and put my hard top back on for the MILD winters we have up here.
