Ok, I have ordered a Fiberglass Half Cab for my '76 from Bronco Design. Along with a windshield motor lowering bracket. The guy from Bronco Design has been very helpful and he is going to install a 2 inch wide steel plate along the inside of the cab (over the windshield) so I can install 2 of these over the front windshield.
http://www.mscdirect.com/product/details/32856072?fromRR=Y
Now my problem I am running into is what kind of clamping system to use on the rear. As you may know (and if not I attatched pictures) there isn't a lot of room to clamp anything. My bulkhead is a straight up and down model and I was wanting to fasten something like this
https://www.zoro.com/value-brand-la...gclid=CJacip6ZgMsCFQcUHwodebQExg&gclsrc=aw.ds
One in the middle of the half cab and one in each corner. The main part of the clamp will be connected to the bulkhead and pulled DOWN to secure.
My question is does anyone see a problem with me doing this?? Will the two clamps up front be enough? Jeeps only use two and since the windshield motor is kinda in the way I figure 2 would be fine, about 8-10 inches from the sides. Or is there a better clamp system out there that I don't know of?
Mark
Mark
