As mentioned in the title, The cap on my overflow bottle is leaking (bad). The more i bounce the truck around the worse the cap leaks. The tank is in good shape but the cap wont snap down tight and make a good seal. I tried putting a wrap of electrical tape around the cap flange and using a hose clamp around the cap to tighten the seal. This Band-Aid fix helped but it still leaks enough to be a mess all over the inner fender when off road. Have any of you guys/gals had a similar problem and came up with a whiz-bang fix so that i don't have to buy a new bottle just for the cap. I don't mind spending the money on a new bottle if that is the proper fix but with the vast experience of the bronco folks here on this forum there has to be something out there that somebody has used to address this problem before.
Thanks in advance for your suggestions.
CK
CK
