- Mar 2, 2013
- 2,671
I have been thinking about modifying my radius arm brackets to gain a little caster before I get my frame painted. I was thinking of taking the round piece that is welded to the radius arm bracket off. Notching the bottom of the bracket and then adding a piece of 3/4 plate with a hole in it for the radius arm that is the full length of the bracket with a 1 inch drop added in.
I have a WH 3.5" lift. On my last Bronco I the same lift and could have used a little more caster, that's what started this thought process. I was going to modify a set of radius arms but I thought this might be a simpler solution.
I don't play in the rocks, just wheeling in the mountains while hunting and enjoying the outdoors. I don't think the clearance will be an issue.
Any thoughts?
Thanks in advance!
Any thoughts?
Thanks in advance!
