Raptor Liner Prep Questions
jdeignan
I've seen a few different threads on this but I'm lookingg for some prep help.
The interior is painted black. Not bare metal.
1. Im using scotchbrite (maroon) scuffing pads. It seems to be making quick work since its kicking up a ton of paint dust. But how visible should the scuffs be?
After I wipe the area down I can barely see the abrasion marks.
Am I wasting my time?
needabronco
Prescott/Farmington
You need to ptep it good, if you dont get mechanicsl bite it will literally peel off. You can use a red scuff pad. I used to shoot Rapter at around 90 psi to get my preffered texture. Practice on a sheet of cardboard before shooting metal. Use plastic sheets snd protect everything you do not want Raptor on, including your garage walls floors or anything else it splatters and goes everywhere
jmangi62
You should be good, the liner needs to get a good bite on the metal. I used extreme liner and it states to scuff with a maroon pad. It also says to spray over scuffed paint or primer, ( not bare metal ). So your on the right track, clean really good after scuffing and spray away. And like needabronco said, plan on a mess, but its not really that bad, I sprayed mine in my garage and only had a sheet of plastic around one side and that was good enuff, but everyone has their own way of doing things, sorry bout the sideways pics lol. good luck. :cool:
RADO
Phoenix
I just sprayed raptor liner this weekend and it was surprisingly easy. I used a paint scuffer drill attachment to swirl everything and breakthrough the clear coat. There was very little dust and you could clearly see the scuff marks.
I sprayed at 50 PSI in 70 degree weather and it went quick and clean. The longest part was waiting 60 minutes to apply a second coat. The results look awesome!
jdeignan
jdeignan
Damn! Mind linking me to whatever attachment you used? Once I wipe the dust, I barely see anything
jdeignan
jdeignan
Thanks. That looks super heavy duty like its going to take the paint off but ill give it a shot.
I think I'm getting somewhere with 120 grit sandpaper sponge.
I'm pretty sure the problem is the type of paint the PO used. Its some type of hard coat enamel I think.
