Bullitt94
I'm pulling my rear axles out so I can remove the 3rd member to put a mini spool in. On the driver side I used the drum as a slide hammer method to pull the axle, and in less than 5 min I had the axle out. It worked like a charm and I was feeling good.
So i moved to the passanger side and have been at it for over 3 hours now with no luck. I don't think I even budged it. I'm not feeling so good anymore.
I've been trying the drum method and even went as far as to put a high lift jack between the leaf spring and axle flange to spread it hoping to pop it free, but I can't get it to go. I have not yet gone to rent a slide hammer since I needed to take a break from it for a while first. I'm having my doubts about whether it will work or not. Before I do go rent one, does anyone have any good ideas to at least get the s.o.b. to budge?
