Rear Bench Seat
bronco_daddy
bronco_daddy
Paso Robles, CA
wow, I am really throwing a brain fart here. Ok, appease the old guy...there are two sets of seat belts, each set has a male and female. Did these two share a common bolt hole or where they mounted separate of one another? Man, time for some thinking Tequila
Fireball05
Separate. If you've got carpet look at this photo and count the ridges and you should be able to find them. ImageUploadedByTapatalk1360898722.873157.jpg
Fireball05
There ya go! Glad you had them and found them.
Mine didn't come with a backseat originally, so no holes. Actually, a PO had drilled holes for the seat, but they weren't in the right location. Luckily FORD actually marked the holes for both the seat and the belts, so I knew exactly where the were supposed to go, just had to go through the effort of drilling the holes and welding the various nuts to the underside.
bronco_daddy
bronco_daddy
Paso Robles, CA
Unfortunately the rear seat was installed as my Bronco has been sold to New Jersey...and yes it makes new totally sad. Loved the truck, loved the brotherhood more...
Bob, ex Bronco owner
garberz
Bronco Influencer
Conejo Valley, Ca.
That's it? Your out? I'd still like to have a beer with you sometime, we can talk dogs.
Mark
